Yet another Q about bearing walls
If a bearing wall 13' wide has a 48'' openning and the header is a single 2''x8'' suported by jack studs would it be wrong to assume that if another 48'' openning along the wall was created , suported the same way, an identical header 2x8 should be OK?
Thank you
Thank you
