How strong is this ceiling
Old 01-27-09, 07:06 PM
My garage ceiling is made of 2x6's that run 19.5' from front to back of the garage. Currently there is the garage door and opener hanging off of it along with a shelf above the door. I have a 7' door and 12' ceilings. I am thinking of adding sheetrock to the ceiling and flooring for more storage in the attic. My guess is the ceiling was only there to tie the walls together and not to support weight. Will i be overloading the 2x6's? Do i need to add a beam to support the center?
Old 01-27-09, 07:16 PM
mikeTN's Avatar
Smile
2x6 ceiling joist 19.5 feet in length are unusual, but they are still to light to support any weight of any consequence. If I were going to store much up there, I would add support underneath. You can put a beam on top if you have something to sit the ends on for support and use hangers for each of the joists.
Old 01-27-09, 07:57 PM
I wasnt looking to put to much weight up there becouse i would have to carry it up there. I was more concerned about it being able to support the sheetrock, some flooring and my weight.
Old 01-28-09, 04:55 AM
chandler's Avatar
Unless the 2x6's are part of a truss system, they may be overloaded without your Christmas ornaments. The normal span of Southern Pine of 2x6's is 11'2" (24"oc) and 12'9" (16"oc). Not sure what lumber you have.
Old 01-31-09, 12:54 PM
mikeTN's Avatar
Smile
You will be surprised how fast things accumulate once there is space and the ability to get to it.
