What does it means?
Old 02-05-09, 08:31 PM
R
What does it means?
From an structural engineer report
''Posts should be blocked solidly in the joist cavity''
Thank you
Old 02-06-09, 05:16 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Blocking a post would fix the post so that it can't move horizontally in any direction. Blocking is usually a horizontal framing member between studs. In your case the blocking would be installed around the post so that the post could not move.
Old 02-06-09, 09:51 AM
R
Thanks for reply, blocking the post in the joist cavity ,does it mean cutting a hole on the bottom plate/floor and setting/blocking the post on top of the joist?
Old 02-07-09, 06:14 AM
D
measure the distance between the post (verticals or horizontal as truss) using the same size lumber cut pieces for 16" oc should be 14.5" long piece or 24"oc should be 22.5" set them horizontally at about 4 feet from floor and nail/screw them in betweeen the post, you will have to stager them so you can nail/screw them, you do not have to cut any holes, basically you are bracing the post with each other for a firmer/stronger built, this is also used in the top plate (if second floor is to be build as a fire retardant) codes will vary from state to state, so check in your local area!!Beer 4U2
Old 02-07-09, 08:32 PM
B
From my experience solid blocking for posts always meant to put solid wood (usually joist cut offs) between the underside of the plywood where the post sits above and the top of the wall or beam the post is over. The blocking needs to be as big as or bigger than the footprint of the post. This carries the point load to the beam or wall. If there was no blocking the floor would settle under and around the post at some point in time.
Old 02-07-09, 11:06 PM
R
Thanks for all the replies,the report points out the need to beef up the floor joists where the posts will seat .The new built up beam is 3-2x10 nailed to the existing joist bearing on a steel beam and a LBW. Im an absolute novice , I got the report to see if some parts of the reno Im doing at home were doable but the quotes I got from different contractors to do the job were much more than I anticipated so for now Im just traying to understand what has to be done.
The diagram shows the post on top of the new beam, there is no floor drawn
I thought the joist cavity refers to the space between the joist, therefore my question about setting the post on the built up joist not on the floor above it .
Again thank you all for the help
