Basic Framing Qs
Basic Framing Qs
This is a bearing wall 13' wide with a 48'' opening in the middle 1-2x10 header
Im wondering if this are problems and how to fix them before hanging the drywall
King stud other side not nailed to top plate.
Should I nail it same as the other side?
Trimmer not nail to header
Is this OK?
Not visible but header is not bearing on trimmer other side[1/8 gap]
Should I shimmy it?
Othar studs/ top plate no visible nails
Is this OK?
Top plate bears only on half of stud
Should I sister with a full lenght stud to existing and also nail it to the top plate ?
Can I substitute nails with screws?
Thanks a lot
Is this OK?
Should I shimmy it?
Is this OK?
Thanks a lot
