floor joist reinforement
Welcome to the forums! If you can gain access below the floor, cut the joist back at least 2" shorter than the required space for the register. Then, between the two adjacent joists secure a spanner joist across the end of the joist you cut and attach it to the two joists. This will spread the weight from the end of the cut joist to the two adjacent joists. Be sure to give yourself enough room to install the register and the ductwork.
