Nails for subfloor?
MikeVila's Avatar
OH
03-13-09, 07:27 PM   #1
Nails for subfloor?
What is the correct nails to use for nailing down OSB subfloor? Had to cut out a section to move a drain/vent line and also noticed where factory missed with about a dozen staples down one joist. Could be why it squeeks there a? Thx.
Rivethead's Avatar
OH
03-13-09, 08:49 PM   #2
A box of Grip Rite 1 7/8ths ring shank underlayment nails will do the trick. Run them about every 6 to 8 inches - I think your squeak will go away.
jatco's Avatar
CANADA
03-13-09, 08:58 PM   #3
Why not use screws? generally hold better, nespas!
Gunguy45's Avatar
Super Moderator
AZ
03-14-09, 07:45 AM   #4
Yep, I'd have to agree..the correct nail is a screw. A deck screw...not a drywall screw.
Absolutely, ringshank nails will work and hold...but screws will work and hold better
Vic
"I sometimes wonder how some people ever made it to adulthood..."
stickshift's Avatar
WI
03-14-09, 08:11 PM   #5
I'm a screw guy myself. I've always used drywall screws without any problems.
jatco's Avatar
CANADA
03-14-09, 08:39 PM   #6
Uh...
Drywall screws are meant for drywall, deck screws are intended for decks, - when it comes to flooring, I use flooring screws, phillips head, as they are intended for.
The right product for the application it is for...
Thats my $.02 worth...!!
stickshift's Avatar
WI
03-14-09, 10:22 PM   #7
Not disagreeing with anyone here, just saying I've used drywall screws with good results. What are the differences between these types of screws to make one a better choice than another?
Gunguy45's Avatar
Super Moderator
AZ
03-15-09, 06:34 AM   #8
I didn't know they even made flooring screws...so I can plead ignorance on that. And I'm no flooring guy so I haven't done alot...but I've seen too many heads snap off on drywall screws when being used for attaching ply or OSB to lumber.
Anyone can use what they like and are comfortable with
Vic
stickshift's Avatar
WI
03-15-09, 07:45 AM   #9
So the deck screw is stronger than the drywall screw? I'm ignorant enough I thought the difference between a deck and a drywall screw was just weather tolerance.
Gunguy45's Avatar
Super Moderator
AZ
03-15-09, 08:00 AM   #10
Mitch...I may not have been clear. Regular exterior screws..the galvanized kind...are pretty much the same as drywall screws..at least to my eyes.
I was talking about Deck Mate screws or similar. They have a much thicker shank and head for the same length. The threads are also a bit deeper and have a coarser pitch.
They also have square, combo, or torx heads so much less chance of stripping.
As I said...just my preference. Besides I probably have more of them floating around from not being able to find the last box I bought, every time I start a new project...lol
Vic
stickshift's Avatar
WI
03-15-09, 08:56 AM   #11
Sounds good to me. I've been using square head drywall screws, I hate phillips head screws!
