Placement of strap ties
Old 04-12-09, 09:24 PM
I'm using strap rafter ties (e.g., USP RT24F) to tie trimmer studs above windows and doors to the the header, top plate, and beam above it in 2x6 framing. I'm looking at a diagram showing these ties used for this purpose, but it only shows the outside of the wall.
Can someone tell me if these straps are usually installed on the outside only or on both the inside and outside of the framed wall?
I'd just put them on both sides except the recommended fasteners are 16d nails (3-1/2"), with 14 nails at each end of the strap. Even in 2x6 framing, if installed on both sides of studs the nails will be crossing each other in the middle of the stud.
Thanks!
Steve
Old 04-14-09, 06:25 PM
The straps you listed are for wood to masonry connection. 6- screws in masonry, 9- 16d nails in wood, for uplift shear. Not applicable to wood/wood, but will work.
http://www.uspconnectors.com/pdfs/rt24fmasonry.pdf
I have never strapped trimmers(under a header) to the header, it wasn't required.
The wall sheathing will connect the two, though just 3-16d toe-nails work.
One side is fine, either or. Remember inside, it will push your sheetrock out, and make for difficult installation. Outside, it bows the wall sheathing........ Be safe, GBAR
Old 04-19-09, 12:04 PM
The F (flat) straps are primarily for wood. Link below only lists 16d nails as fasteners, so primary application is wood. http://www.uspconnectors.com/pdf-ful...7/85%2C210.pdf
Apparently from the link you posted, they can also be used in masonry with masonry screws.
FL code requires stud plate ties top and bottom all studs, and requires 2x6 on new framing. These things wrap over the top plate and bottom plate and are nailed to the edges of the studs. I doubt sheathing, siding, or drywall will be flat with all that metal underneath! But then, it's a garage . . .
Thanks!
Old 04-19-09, 02:07 PM
You are correct. I found this: http://www.dca.state.fl.us/fbc/Hurri...draft%20v2.doc
Notice: A104.3.1 talking about minimum 20 gauge straps nailed with 1-1/2" nails, screws, or 8d (2-1/2"0 nails). Be safe, GBR
