drilling through vinyl siding
dominic67's Avatar
05-25-09, 05:50 AM   #1
Good morning
I need to drill a 1 inch hole through vinyl siding and the plywood sheathing to run a 1 inch PVC pipe.
Any pointers as to what type of drill bit to use and the best way of doing this? With vinyl siding there are no "do overs".
thanks so much.
Wirepuller38's Avatar
TN
05-25-09, 06:20 AM   #2
Siding
Use a hole saw. Measure the outside diameter of the PVC pipe to get the size of the hole saw needed.
chandler's Avatar
GA
05-25-09, 04:03 PM   #3
I agree, it will give you a pilot to keep your hand steady. A 1" pvc pipe will probably take a 1 1/4" hole to fit good.
