1/4 " cement board
Old 07-16-09, 03:16 PM
P
Received 1 Vote on 1 Post
1/4 " cement board
Hello
Is this a good material to apply over my embossed sheet vinyl kitchen floor before applying a new sheet of sheet vinyl?
If so, what would I use to adhere the cement board to the old floor?
Thank you
Old 07-16-09, 04:08 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Others may have differing views, but the cbu won't give a smooth surface that will be required for sheet vinyl. All the aberrations in the surface of the cbu will telegraph to the surface. Even laying sheet vinyl over old patterned sheet vinyl will cause the telegraphing of the pattern to the top strata.
Old 07-16-09, 04:25 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Either use the embossing leveler for vinyl..it sits in the pattern and gives a flat surface...or use 1/4" plywood and fill the seams after its down.
Old 07-16-09, 06:06 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
When I was young lad it was routine to use untempered, single surface " hardboard as underlayment. Can't say if they still do. I've seen 3/8" CDX used a lot more recently but it gives you a really crappy surface.
Old 07-17-09, 06:29 AM
P
cbu
I was going to persue this with you but I'll get to Home depot and not tie things up here.
Btw, have you noticed that when you sign in, the message box 'thanks you', but does not let you reply. I have had to try about fifteen times in the last 2 days before I could post or reply.
I have been coming here for years and years and never had trouble with the software.
Nothing else on my end is giving me a problem.
This is not a complaint as this is probably my favorite site to visit and learn, but I wanted someone to know so they could fix it if necessary.
I wanted to let the software moderator know this but did not know how;I sent a feedback but had trouble with that.
Anyway, thank you for the reply.
Old 07-17-09, 06:43 AM
H
Received 7 Votes on 7 Posts
cdx is not rated as a floor underlayment and shouldn't be used as such. I not surprised at the "crappy surface" results.
Old 07-17-09, 07:27 AM
P
results
There were no results as I only "asked" but did not do it.
I am going to use the deembosser as I indicated.
I did not want you to be misled.
Old 07-17-09, 08:18 AM
H
Hi Peter
I know you didnt use cdx. I was just commenting on ray's post where he said he has seen cdx used with crappy results.
Good luck with your project.
Old 07-17-09, 08:45 AM
ray2047's Avatar
And to clarify my mention of CDX was only an advanced no=way should a "helpful" friend suggest it.
Heck, I once was went to give an estimate for a bathroom floor where the contractor had used particle board as underlayment for vinyl tile. Old claw foot tub and several small kids (she did day care), Any guesses what the floor looked like after only a few months Would you believe the person who installed it wasn't answering his phone.Had swore to her it was the best thing you could use. Jeeze.
Old 07-17-09, 09:53 AM
P
vinyl floor
Can you help me get started? Here is where I stand:
1- Pull the baseboards.
2- What is involved in debossing which seems to be the next step?
2- Get a kit to draw a template. ?safer than measuring.
3- let the new section of vinyl relax for a day.
4- cut the new section according to the template
5- Remove the dishwasher so I can vinyl back to the wall
and water cannot get under the vinyl.
6- How do I cement the vinyl to the old deembossed one?
7- Do I really need a commercial roller?
8- Build baseboards back into place
(I guess you put the appliances on ?cardboard in the adjacent room)
The above is what I can gather by reading on line.
Each site seems to start ok then they stray or become vague.
Thank you if you can help.
Old 07-17-09, 11:20 AM
G
I, too, have trouble after I log in the normal way. If I go to the next page or to reply, it forgets my name. I started using the "login" above the box and have not had any trouble since. Click on "Limited preview" in red, at each book for info.:
install new vinyl flooring - Google Books Be safe, G
Old 07-17-09, 11:38 AM
Gunguy45's Avatar
Super Moderator
On the log in thing...I haven't actually logged in in months. Either I have it set to "remember me"...or I spend way to much time on here...lol.
Old 07-17-09, 07:25 PM
chandler's Avatar
I do "remember me", and it forgets me. I have to log in each time I close my browser.
