Subfloor for hardwood
Received 0 Votes
Hey all,
In the process of constructing a new home and am getting ready to lay a solid 3/4" hickory floor.
I currently have 3/4" Advantech for the subfloor, would it be wise to apply an underlayment of some sort?? CDX? Particaleboard? If so, do you recommend a moisture barrier between the two or just under the hardwood?
The flooring will be running perpendicular to the joists.
Thanks in advance!
Thanks in advance!
