Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Keeping green wood from warping and spliting as it dries
Old 12-07-09, 12:43 PM
I am new to the forum and need your help. I am working on a crazy project. I need to glue seven 6x6x96 inch Douglass fir timbers together along their length to make a 38.5 x 96 in. SOLID wood rectangle. I am going to drill every 12 inches across and use 5/8 threaded rod to add extra holding power. Because it will be laying flat on concrete I plan to put it on a redwood plate to protect it from rot. The problem I am having is that the fir is green. What can I do to keep it from splitting and warping when It dries? Can it be done?
Thank you
Old 12-07-09, 05:30 PM
It cannot be done. You can attempt to minimize end checks by coating them with wax.
I wouldn't do anything with it until it is dry. You may have trouble gluing it while it is still wet.
Old 12-08-09, 08:19 AM
I don't know your application or the exact design of the block you are constructing, but I see no reason why you can't prevent warping during the drying process.
Green lumber is used quite a bit in construction. The trick is to get it securely fastened before it warps/dries. If I were doing this I would use Gorilla glue and lots of clamps or blocking. The inside blocks could be nailed or screwed together to hold them securely.
Old 12-17-09, 11:11 AM
The gorilla glue will work fine with the moisture, for sure, but its working time is extremely short--no more than five minutes (less is ideal), so you'd have to be quick!
