Basement Framing Issue
Old 01-18-10, 12:17 PM
Beginning to frame out my basement..how do I lay out bottom plates & make sure that they are straight? The bottom of the walls are not straight...help. Thanks.
Old 01-18-10, 12:30 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You'll have to figure out what IS straight and snap a line along the straight part and lay your plate along this line. Can you figure out the way it is supposed to be? Give yourself about an inch away from the wall to ensure the wall doesn't move into or away from your plate too much.
Old 01-18-10, 01:16 PM
Received 1 Upvote on 1 Post
Definitely have to snap a line with the chalk string, the stuff is cheap from home depot. If walls are not properly vertical and they likely aren't you'll want to be out, as mentioned, from the wall so that your finished, framed walls ARE vertical.
Old 02-08-10, 10:59 AM
Thanks...I bought an Irwin Chalk snapline...I was also told that I could use a plumb bob...is the Home Depot guy correct?
Old 02-08-10, 11:34 AM
You can. I have not bothered, I just stuck my first pre-built wall up last night just using a 4' level against the studs--against a few of them since they all curve a little differently here and there. I think that if it's good with the level it's going to be good to the eye so I am not going to bother with a plumb bob. If you are building the walls in place a plumb bob would make it easier but if you're building it on the floor first "it is what it is", so the level should get you sorted out.
Old 02-08-10, 11:49 AM
Thanks...That's what I did...I built the walls on the floor & raised them up.
Old 02-15-10, 03:59 PM
straight is the east part- how about square?
I would suggest that before you anchor any plates to the floor, you make sure they are going to be square before you even worry about them being level. 3/4/5/ to square first, then snap your line, then take one board that is not bowed, level that and then mark your joists up top. THEN when you put up your walls, check several for level and come as close as you can to that. I am not sure where you live, but another good idea for colder climates is to install insulating board to the back or your studs, put your walls us, then insulate prior to dry wall. No moisture on the back of the drywall that way.
