Convert wood subfloor/joists to concrete pad
Old 02-27-10, 05:40 AM
I searched the forums for this, but if I missed the answer somewhere - please point me in the right direct.
I have structure that is built over a crawlspace. I would like to convert the first floor to a concrete pad to be used as a garage. There are no utilities located in this crawlspace.
At first it would seem simple - remove sub-floor/joists - backfill with dirt and compact - add gravel - then pour concrete... but the dilemma arises at the perimeter walls. The exterior load bearing walls are built on top of the sub-floor/joists/sill plate.
Any suggestions what to do with the sill/joists/sub-floor directly under the walls? Pouring the concrete around them does not seem to be correct as they would eventually rot.
thanx in advance for your suggestions
Old 02-27-10, 12:30 PM
Temporarily Suspended
You're talking about a major structural change which could be problematic to say the least.
If I wanted to do that, I would probably leave the joists there, fill between them & then pour the gravel & cement to cover everything.
Old 03-10-10, 07:23 PM
wsaend's Avatar
I agree it will be a feat. You would have to support the second floor while you cut the wall at the bottom and put in a footer to support the wall. And you obviously can't use the existing floor for support. But a picture would help to see what you are attempting. Sounds like a fun project. You would want to get plans from an engineer.
Trackbacks are On
Pingbacks are On
Refbacks are On
