Repair Structural Insulated Panels?
JimmyJamesJimbo's Avatar
OH
06-22-10, 01:59 PM   #1
How could a homeowner repair damaged SIP panels? I have an addition made out of SIPs from a previous homeowner. (SIPs are the styrofoam sandwiched between two layers of plywood.)
The panels have water and carpenter ant damage, but I am not sure yet of the extent. I have some ideas... like cutting the exterior plywood and insterting 2x6s for support. This would basically be replacing the SIPS with stick framing from the outside in. Has anyone had this issue?
Pulpo's Avatar
Temporarily Suspended
NY
06-28-10, 06:43 PM   #2
It sounds like it all has to be removed in order to avoid a mold problem. Your solution handles the structural question only.
bobarchitect39's Avatar
CAL
07-06-10, 08:15 AM   #3
Removing it is your best bet, remove any doubt about the situation and ensure that the mold will be gone/not coming back. Go with that.
