Concrete Floor
Shans's Avatar
AL
09-03-10, 03:16 AM   #1
Concrete Floor
We converted a screened-in porch to a room. It has a concrete slab floor. What type of flooring can I install on the concrete slab? What preparations do I need to install the floor? Thanks!!
chandler's Avatar
GA
09-03-10, 03:39 AM   #2
Welcome to the forums! Probably the best covering would be ceramic tile. I know it is cold and hard, but it is sturdy, easy to keep clean and you can always use throw rugs for decoration and foot comfort as you don't like the feel of tile.
I am gathering this is on grade level. If you are confident of no water making its way into the room, you could always carpet it, or use laminate flooring with proper padding. Really depends on what your likes and dislikes are.
stickshift's Avatar
WI
09-03-10, 05:36 AM   #3
I'm with Chandler - ceramic is the best choice, others would hinge on the floor staying dry
GBR in WA's Avatar
WA
09-03-10, 04:13 PM   #4
Fig. 2: BSI-003: Concrete Floor Problems — Building Science Information As you probably don't know if there is a vapor barrier under the floor which started as a slab, to a screened porch, to a room- without footings or stem walls, I'm guessing. Be careful of the siding matierial unless you elevated the perimeter above grade.
Gary
