Uneven concrete subfloor floor and adjacent sill
BGC's Avatar
CAL
10-04-10, 01:32 AM   #1
I removed my sliding glass door and discovered settlement of 1/2" in the subfloor adjacent to the slider, the sill is deteriorated, sill is lower than it should be and sill is lower than the exterior concrete slab.
This is a hillside house, room is below street level. What is the best way to get the height of the sill correct? I was thinking of a sill made of 4" x 6" oak. The other idea was to remove the existing wood sill and pour a concrete sill to the level of the subfloor that has not settled.
Pulpo's Avatar
Temporarily Suspended
NY
10-04-10, 03:43 PM   #2
Is the sill deteriorated due to water damage? Is so, it should be removed.
BGC's Avatar
CAL
10-04-10, 08:23 PM   #3
Sill is bad from water, dry-rot, age. Since it is lower than the concrete subfloor and lower than the adjacent exterior slab I can't replace with a 2" x 6" piece of lumber - the height will be wrong. I can install a new sill made of 4" x 6" oak. The other idea was to remove the existing wood sill and pour a concrete sill to the level of the subfloor that has not settled. I have attached 4 photos the should appear below.
The question is: how do I get the sill height correct - concrete or lumber? And, how high is correct? Should sill be even with concrete subfloor? Higher than subfloor?
BGC's Avatar
CAL
10-04-10, 08:30 PM   #4
I can't see the photos I tried to post - Here is 1 of the 4:
BGC's Avatar
CAL
10-04-10, 08:38 PM   #5
SD530816 | Flickr - Photo Sharing!
Pulpo's Avatar
NY
10-05-10, 02:42 PM   #6
All rotted wood has to be removed. If you plan to reuse the sliding glass door, it doesn't matter if you use wood or cement or a combination of the two, as long as you can attach the bottom track to it.
