Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Will another layer of ply fix a slight floor bounce?
Old 01-16-11, 03:29 PM
I posted about this issue in the flooring tile section and got the answer that I expected (that it would crack the tile). So I am coming to you subfloor experts to help me fix it.
I am remodeling an upstairs bathroom in an old farm house. It has 2x6 joists. I knew that there was a sag issue (the previous owners had a bathtub that was WAY to heavy for the floor). So I laminated some new 2x6's to the existing joists in that area. I got my subfloor down (3/4 ply) and noticed that there is a little bit of flex (maybe 1/8" tops when a 215 lb man stands on 1 foot and bounces up and down. I would really rather not pull up the entire floor and rerun my wiring to laminate new 2x6's to the joists. Can I just throw another layer of 3/4 ply on? Will this help stiffen up the floor or will it just add to my problem?
Old 01-16-11, 03:35 PM
Tolyn Ironhand's Avatar
IMO - install a 1/2 hardie backer board that is put down with thinset and screws.
Old 01-16-11, 04:10 PM
chandler's Avatar
I have a brother in law who does that with doctors. He goes to one and another until he gets the answer he likes. May not be right, but he likes it.
Your second layer, if you should choose to go that way, should not be screwed into the joists, but only into the original 3/4" subflooring. Before you lay it down, make sure the original subflooring is only screwed to the floor joists. Then use 1/4" backer set in thinset and screwed with proper backer screws.
This brings your floor up a little, but should be sturdier.
