Pole Barn Floor
Old 01-24-12, 01:04 PM
Pole Barn Floor
I'm building a 40x72 pole barn and would like to put a wood floor in it. Any suggestions?
Old 01-24-12, 02:17 PM
What are you using the pole barn for?
Depending on the use, there could be limited options from an economical standpoint.
Dick
Old 01-24-12, 03:16 PM
Concrete would probably be better. The wood floor framing would need air movement underneath to prevent rot..... that might raise the floor more than you want
btw - welcome to the forums!
Old 01-24-12, 05:14 PM
badeyeben's Avatar
Are you planning to put wood in the entire barn or just a certain area? Also if you are planning to put heat ducts or water and drain pipes under the floor then that will determine the height of the floor.
You could build a deck in the barn if that would suffice!
