What's the Deal with Pneumatic Nail Sizes?
Received 0 Votes
I just started a project to build a shed in my back yard. I decided to invest in a nailer, for which I have also purchased collated nails. My plans call for a combination of 16D-common, 10D-common, 8D-common and 10Dx1+1/2 galvinized nails. I'm gradually reaching acceptance of the fact that I'll have to shell out $100 to buy the IBC, just to be sure (topic for another forum: why should I have to pay to know the law?), but I've done alot of reseach, all of which indicates that this is typical and often required by code. So, why can't I easily buy these sizes of collated nails? When I go into my local home improvement store, I see no collated nails larger in diameter than .131 or longer than 3+1/4": which seems deficient on both counts for the purposes of being plan and code compliant. It seems like 16D-common and 10D-common bright and galvanized should be readily available, if everyone is doing it to-code and to-plan. Am I wrong regarding what I perceive to be a common code requirement? Is there a typical clause or exception for pneumatic nails that I just don't know about?
Welcome to the forums! Your profile shows you live in Georgia. We have no code compliance with collated nails that I am aware of. Florida requires round head, as do other states. I have never had a clipped head nail fail in all the years I have been in the business. Why do you need a nail longer than 3 1/4" and larger in diameter than .131??
A little background would help. Where are you getting your information?
Received 0 Votes
Hi chandler,
Do you mean that you cannot comply with code in Georgia when using collated nails, or that there is no compliance issue in Georgia with collated nails? My nailer shoots full round headed nails, so that in particular shouldn't be an issue. My information is coming mostly from the internet, right now (I know). For example, a post in this thread by Doug Aleshire indicates that, according to the IRC, you must use 2 16D nails to nail a rafter to a top plate. That entire thread is a debate about what sized nails to frame with. I've almost resigned myself to buy a copy of the IBC or IRC (don't know which, yet), to see what it has to say about the subject in general.
Hi Tolyn,
Well, you might be on to something, here. After all, do you mean 16D common (3-1/2 x .162), 16D sinker (3-1/4 x .148), or 16D short (3-1/4 x .131)? If you see plans or directions that specify a "16D", which variety are you to assume? The web site that I pulled those dimensions from indicates that the 16D shorts, which are the ones I can readily buy, are not recommended for framing because they have only 70% of the capacity of the other two. More fuel for my question: if that's so, why is that the biggest collated framing nail the stores in my area stock? FWIW, my plans specify 16D common.
Hi Tolyn,
Why are you worried about the UBC code? You will have to conform to local codes anyway, and if they use UBC, IRC or the Southern Building Code, so be it. If you are nailing two dimensional 2x pieces of lumber together, they total 3". If you use a 3 1/4" nail even at a slight angle, you will penetrate 90% of the two boards. If you shoot a 3 1/2" nail, you will have wasted steel sticking out of your lumber, so if your plans call for 16D common, buy an Estwing 24 oz hammer. You are talking apples and pears when you compare common nails and collated nails.
Don't get caught up on codification issues unless it bears directly on your locale (speaking of which, where are you located in Georgia?). Check with your local building inspector and see what they have to say about it. After all it is the inspector who will sign off on your permits, not us.
Received 0 Votes
As far as I know, 3.25" is the longest framing gun nail you can get.
IMO it's better use the hurricane clips to fasten the rafter to the top plate.
Received 0 Votes
Sure, but consider end-nailing joists, or nailing trusses to top plates.
In your reference to the IBC, you will note there are nailing specs for common (.162) and for collated (.131) Generally it speaks of using 2 common or 3 collated. It is how you read the material. You can buy (.131) nails all day at big orange or blue and use them successfully. The larger diameter nails won't feed in your gun, betcha.
Received 0 Votes
