OSB sub-floor smooth or rough side up?
Old 06-29-12, 03:43 PM
R
Hey gang,
Renovating a bathroom. I have cut and fitted an 3/4" OSB subfloor, with the shiny side up. I plan to put down an electric radiant floor mat, then Ditra, then the tile. My question is will the shiny side hold the thinset?
If not I'll have to buy two new pieces and use the existing pieces as a template. The bathroom is trapezoidal in shape, and the pieces are not symetrical in the slightest.
Thanks.
Old 06-30-12, 07:14 PM
P
Temporarily Suspended
Some of them are stamped, up or out.
Old 07-25-12, 07:40 AM
OSB is not appropriate for a subfloor. Especially in a bathroom.
Old 07-25-12, 07:58 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Wait till the water gets too it and it is so mushy you have to remove it with a spoon. I know they use it on roofs but the one leaky roof I encountered with OSB my hand went right through where the water had leaked. Years ago I have seen the effect of water on a similar product, particle board, in a bath room. Totally disintegrated.
Old 07-25-12, 09:41 AM
W
Received 1 Vote on 1 Post
Just like plywood there are differing grades of OSB. Use the correct OSB and you won't have a problem. Schluter says on hteir website that OSB is a suitable subfloor for Ditra.
I've never used OSB under Ditra but I would not hesitate. I have no idea though about what side up. Try an e-mail to the thinset manufacturer or to Schluter customer service.
Old 07-25-12, 03:08 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Rough side up, mainly for footing. It is imprinted on the sheet anyway. Always use a proper subflooring material such as Advantech. Although it is an OSB material it has an impregnation that wards off water damage. Nonetheless, your Ditra installation should take care of it all, and as Wayne says, they approve OSB.
Old 07-30-12, 09:00 PM
G
Joist spacing plays a big role....... initial application; https://docs.google.com/viewer?a=v&q...Nl0Ggpec6X2jug
Tile... may want to stiffen the floor a bit; from the "search" here; http://www.doityourself.com/forum/fl...-subfloor.html
Gary
