Sagging Floors 25 Year old house, two stories
Old 09-25-12, 08:06 PM
Hello,
I am looking for advise on what may be causing sagging floors. My aunt has a 25 year old house in a development in Stowe PA. She bought it about 2 years ago. After about a year, I came over to do some minor plumbing work and noticed the floors in her kitchen (first floor) are sagging badly (about 2.75"). I also noticed directly above the kitchen (master bedroom) that those floors are sagging as well (hard to tell exact amount because of carpeting). I went into the basement that is finished and looked at the floor joists and subfloor. After removing most of the dropped ceiling, I noticed a couple large cracks in the sub floor plywood (1/4 thick running length of plywood). I also noticed the joists have stress cracks in them, and some are not touching the subfloor anymore.
Here is what I believe may be the issue:
1. When whoever finished the basement (looks like before house was sold), they removed a post from the beam. The house is approx 25'D X 25'W, and is a duplex style (each unit is owned, not rented). The main beam is 3 2x12's running the length of the house with all the joists resting on top. The joists are 2x8's spaced 16 OC.
2. There is a custom built island near where the floor is sagging (about 1' away from largest dip). I am estimating that it weighs 400lbs. Is it possible the floor cannot hold this load and is in need of re-structuring?
Any other idea's would be helpful. Unfortunetly at this time she cannot afford an engineer or a contractor. I would like some idea's so when we do have the money we know what we are looking for in a contractor.
Thank you for your help!
Old 09-25-12, 08:26 PM
Nashkat1's Avatar
Welcome to the forums!
What type of cross-blocking is framed in between the joists? Pictures will help us see what you're looking at. See How To Put Pictures In Your Post.
A temporary beam under the area where the island is, with a couple of jack posts under that, might help until you can make more lasting improvements.
Old 09-27-12, 04:25 PM
Hi,thank you for the reply. I actually just left there a few days ago. I live in Boston, her house is outside of philly. I will be back there in a few weeks. I will snap some photo's and put up the temp beam for safety. I actually don't think there is any cross-blocking at all now that I think of it. I will go ahead and post some photos when I come down there.
Old 09-27-12, 05:52 PM
chandler's Avatar
Bingo! I, likewise, agree that new support should be added to the beam. The beam should be jacked up slowly to prevent cracking of walls, etc., maybe over a period of weeks, but I understand your time constraints. Put the support in and jack a little. Over time it will correct itself.
