Weight bearing capacity of flat roof
Old 10-19-12, 12:22 PM
BGC
BGC is offline
Is it possible to estimate the weight bearing capacity of the following flat (7% slope) roof? The room below is open beam.
2" x 6" T & G Western Red Cedar or Douglas Fir over 4" x 10" x 18' beams at 5' OC. Room size is 18' x 30'
Thanks
Old 10-19-12, 12:33 PM
So the 4x10" beams are at 5' OC?
What's the spacing of the 2x6s?
Old 10-19-12, 12:58 PM
BGC
BGC is offline
The 4 x 10 beams are 5' OC.
The 2 x 6 T&G is flat on top of the 4 x 10 beams There is no spacing between the 2 x 6 material.
Old 10-19-12, 01:00 PM
Duh, you said T & G....
Old 10-23-12, 12:48 PM
BridgeMan45's Avatar
Play it safe, and pay an engineer (licensed P.E. in your state) to run the calculations for you. You haven't provided enough information to accurately determine capacity, such as what the beams are composed of, or what the roof sealing surface is composed of.
Old 10-24-12, 02:59 PM
BGC
BGC is offline
I would hire an engineer if I was adding solar panels or equipment to the roof. I'm tearing off 3 rock roofs and adding 1 new one with 1/4" MLV for sound attenuation. The 3 old roofs probably weigh 10 psf. I'll keep my new assembly to 10 psf or less.
Old 10-24-12, 06:22 PM
Since the roof you're adding is likely to be less weight than the 3 layers you're removing (presuming the MLV weighs less than 2 layers of rock), exactly why did you ask the question in the first place?
