float an existing basement wall
mjd2k's Avatar
CANADA
03-27-13, 03:26 AM   #1
Hi,
About 5 years ago I moved into a new house. I hired someone to frame the interior walls. When he was done, he had only floated it about 1 inch. I have since finished the basement. I did not like it but was rushed and he told me it was OK.
However, we are getting some shifting and I'm seeing the float disappear. Is there a way to refloat the walls without tearing out the whole basement?
I'm thinking I can
- cut out about 2 feet of drywall,
- cut off the bottoms of the studs to achieve a new gap,
- then toenail a new plate on the bottom of the studs
- install a new floor plate 2 inches below my toenailed plate.
I know its a lot of work but I want to get the float right.
My biggest question is, is it ok to toenail the bottom plate? I would need to toenail as I can't get underneath to nail up.
Nashkat1's Avatar
VA
03-27-13, 12:26 PM   #2
Sure. Aren't the studs toenailed to the existing bottom plate?
PT lumber for the one that's in contact with the floor, as you probably know.
mjd2k's Avatar
CANADA
03-28-13, 05:55 PM   #3
Thank you for the reply.
No the studs are not toenailed in. When the wall is floated, you can build the wall on the floor first as there is room to stand the wall up. Then you can nail from the bottom of the plate.
I really can't see any reason that wont' work. It would be a problem if it was floated from the top but its floated from the bottom
Nashkat1's Avatar
VA
03-28-13, 07:12 PM   #4
Got it. You can use screws - decking screws or anything but brittle drywall screws - if you want to be a little more certain that it'll hold together.
mjd2k's Avatar
CANADA
01-04-15, 10:04 AM   #5
Forgot about this thread. Interesting I had a couple rental houses flood. Turned out floating an existing wall was an easy job.
One pic is actually from a bathroom with all drywall removed and new plate and gap installed (old house with no float previously). It was easier to do this than rebuild.
The other pic is from other walls already finished. I cut out 33 inches of drywall and put in 4' x 32" drywall panels with only screws in the corners. Then covered the screws with trim. This way I can easily take them off and also did not need to mud/tape. Saved me a week per house. Plus it looked really good.
I'm going to do the same in my house.......one of these days.
Just in case someone else comes across a similiar situation.
LinkBacks (?)
LinkBack to this Thread: https://www.doityourself.com/forum/framing-flooring-sub-flooring/491711-float-existing-basement-wall.html
Posted By For Type Date
Floating Basement Floor | Home Design Styles This thread Refback 10-02-17 12:53 PM
