Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Need to strengthen floor/joists for new bathroom addition?
Old 04-07-13, 06:43 PM
I am having a contractor build a new bathroom (in what used to be a walk-in closet). It's ~8' x 6' with a walk-in shower, toilet, vanity. The new bathroom will be on the 2nd floor, over an open garage area.
He said he would put mortar/cement over the existing floor to create a slope, then tile around the walls and floors.
I was buying and hauling the tiles this weekend, thinking, wow--this stuff is heavy. So I did a quick calculation. Assuming 4lbs/sq ft of tile, I'd have about 800 lbs of tile. That, + the mortar/concrete underneath, + toilet, + vanity and everything else, are we not talking ~2000 lbs of stuff?
That got me a little worried. I was looking at the joists beneath another (existing) bathroom, also over the garage, I noticed that one joist (2x10) is doubled up over that bathroom. (That bathroom does have a bathtub, however, which the new one won't have.)
A bit about the floor structure:
-2x10 joists 16" oc
-The house is old but the joists look to be in good condition
-The span is ~12ft.
-I have no idea what grade of lumber they used, as I can't find a stamp anywhere.
Should I be concerned at all, or am I just making things up to worry about?
P.S. I did try to use these online max span calculators, but since I don't know the lumber grade/material, I'm not sure what to do. I tried Douglas-Fir No. 1, with 50lbs live + 15lbs dead load, and the span came out to ~14.5 ft.
Old 04-07-13, 09:51 PM
Nashkat1's Avatar
It may be fine the way it is as far as supporting the load goes, but I would want to stiffen it a little bit. Cross-blocking with 2x10s - or even 2x8s - 16" o.c. would do that.
I did that after cutting existing joists down by more than 3" and before installing nearly 3' of plywood, concrete and tile in a second floor bath. It never budged.
Old 04-09-13, 03:35 PM
Figure #2 grade, west coast is usually Doug-fir (if older), if really old, could be #1 or Redwood...
A handy help; The Amazing John Bridge Forums Deflect-O-Lator :-)
Gary
Old 04-09-13, 06:52 PM
As Nash mentioned.....add cross bridging to help.
If you were inclined to double up the beams (and I think I might be).....you'd need to remove a good bit of sheetrock in order to get them in.
If you go by that deflect o lator.....the span is too long for masonry.
Old 04-09-13, 10:03 PM
Thank you guys! Much appreciated =) I'll talk to the contractor and see what he can do.
