Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Hanging Jeep Hard top (storage) from garage joists
Old 04-28-13, 09:46 AM
I'd like to hang my Jeep Hardtop in my garage. It weights roughly 150 lbs. I've worked out how going to use straps to life and hang the top, I'm a little more uncertain about how best to attached the straps to the ceiling joists. I need anchors at 4 locations (the corners).
My garage ceiling is drywall with an attic above. I have joists at roughly 12-16" on center.. i need to go up and confirm spacing.
I'm a little concerned about simply screwing in eye-bolts from below into the joists. As I'm screwing through drywall, I'm concerned I won't hit the exact center of the joists and it may pull out. As I have little kids taking toys and bikes in/out of the garage... I need to make sure it's absolutely secure.
My other idea is to attach 2x6's across the top of the joists (from above) and attached a long lag bolt through the 2x6 and then down through the drywall below as the anchor.
Am I over thinking this or is this a more elegant solution?
Thanks
Scott
Old 04-28-13, 10:21 AM
chandler's Avatar
For a balanced 150 lbs, yep, you're over thinking it. You can run a 2x6 in two places (front and back) and screw them (3" #9 torx head decking screws) into the joists, then put your lag eyes anywhere along the 2x6's you need them.
Old 04-28-13, 12:36 PM
If the top fits a JK, you can store it on my jeep
I've always been partial to U-bolts when hanging something heavy from the ceiling and there is access to the top side of the joist.
Old 05-04-13, 05:15 AM
Joists
Use a stud finder on the ceiling to find the center of the ceiling joists.
Old 05-04-13, 11:11 AM
Ok.. got (2) 2x6's mounted as described in "chandler" description. no problem.. easy as pie...
Now.. I'm thinking about using (4) #000-3-7/8" screw eyes that I picked up from home depot. I'm guessing they will have no problem supporting the weight but I can't find a carrying capacity on the packaging. Any concerns of the screw eyes pulling out of the 2x6.. i'm probably over-thinking this again.. but want to be sure....
thanks..
Old 05-04-13, 01:48 PM
Screw eyes should be fine but I prefer to use the ones made like a bolt. A fender washer and a bolt and I know it can't pull out.
