jack stud on floor
jack stud on floor
Hi All.
Is there any reason that a jack stud can't sit on a concrete floor (as apposed to a bottom plate).
Like this:
This would be for an interior 45" wide walkway (non loadbearing).
Reason I ask is that I am widening an existing doorway and have cut the bottom plate but have decided that an additional king stud would be a good idea. So, if I add a King stud, there will be no plate for the jack stud.
I guess I could attach a 1 1/2" plate piece to the floor with liquid nails or something.
Any ideas??
Thanks
Tim
Like this:
Any ideas??
Thanks
Tim
If it's not load bearing I don't see an issue. Just make sure it's treated since it will be in contact with concrete.
I agree with Pilot Dane... treated wood, attached with ACQ compliant fasteners.
You should also have cripples directly over the jack studs above the header.
