Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
I want to add 1/8" plywood subfloor to my existing subfloor
Old 05-08-13, 06:21 AM
As of right nwo I have my formal living room and dining room 1/8" off from the rest of the house. What I would like to do is buy 1/8" plywood to put over my exisiting floors to even out everything so I can run my floors throughout the house evenly. What I would like to know is how I would go about this. My existing subfloor is 3/4".
Should I nail the floors together? Should I screw them together? Do they need to be at the joist? Do I need glue between the floors? Should there by any gaps. Also because of this will I need to cut my dry wall to allow the second subfloor to go underneath it? Any help would be greatful. Thanks in advance.
Old 05-08-13, 12:53 PM
What kind of finish floor will you have? 1/8 inch plywood is not what I would use. Truth is, I would probably just use a tapered transition if using hardwood, nothing if using carpet and a self-leveling compound if using tile.
Old 05-08-13, 04:25 PM
I'd go with the transition as well.
