Simple question: Replace old plank floor with plywood T&G 5/8"?
Received 0 Votes
Pretty simple question ...
~ 1950's house has plank T&G flooring (planks are ~ 4" wide, not sure how thick).
Can I remove planks, replace with 5/8" T&G plywood, put laminate over top and be happy?
Joists are 2x8 16" oc if that matters.
Thanks!
Thanks!
Why do you want to cover the existing floor? Even mere, why do you want to go to the time and effort to tear it out and replace it?
