Load bearing wall in question on 20 x 30 modular/mobile
We just purchased a 20 foot wide (two 10 foot wide by 30 foot long) modular/mobile home. It has wheels under the foundation but has been there since the late 70's so I am not sure what to call it. There is a center wall that only comes forward from the back about 10 feet. The other 20 feet is open. My question is can I remove that 10 foot section in the middle to make one long room?
Since the center wall only runs 1/3 of the length, I am not sure if it is a load bearing or "marriage" wall? Can someone shed some light on this for me please.
Might be the maximum span of the LVL that is supporting the open area. Need to peek at what is going on with the framing to determine any further.
Thank you! I am confused, do you mean above and below the wall? I have decided to run a 2x6 and run it across the room with a span of about 10 feet. It will be attached to the 2x4 studs of the wall.
