Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Basement subfloor, don't even know where to start
Old 10-14-13, 08:20 AM
I am finishing a basement with my father and want to put in a subfloor. I know if there was ever enough water I would probably have to replace the floor anyways but want to give myself a couple inches more to protect the expensive electronics I will have down there. There is also a sewer access port and two ground rods that stick ~ 2 inches above the concrete floor.
We were originally planning to lay down pressure treated 2x4's the tall way getting us over the two obstructions and build a plywood floor on top of it. After that we were going to build two small access panels in the floor should we ever need to get to them.
An uncle who is a carpenter stopped by this weekend and said if it was his basement he would not even bother building a subfloor. He said the basement was bone dry and it would be a waste. Even if we did get water it would be trapped in between the 2x4's with no way to get it out. The obstructions are in a corner so we would just box them in somehow going that direction.
This now puts me back to planning. I can't see a disadvantage to building a subfloor other than money and height though the ceiling down there is 8ft so height is not an issue.
What is the best way to build the basement subfloor?
I have seen other methods such as Dri-Core or Delta-FL also suggested. Ideally I would like to create channels so I could somewhat push water out should I ever have an issue down there. From concrete to carpet please advise me exactly what I need to do in-between.
Old 10-14-13, 07:40 PM
Temporarily Suspended
I agree with your uncle. I wouldn't bother with a sub-floor but if you insist, sub-floors on concrete are usually 3/4 plywood, on top of it. Also, search google for 'raised floor systems'. That's another choice.
Old 10-14-13, 07:54 PM
With the ground temps at 48-49*F and spring/summer time you could have a problem; Average Shallow GroundWater Temperatures | Ecosystems Research | US EPA
Page 4; http://www.buildingscience.com/docum...g-your-basment
Delta FL or similar would equalize the pressure, stopping the vapor drive; DELTAŽ-FL - Vapor Barrier for installation on concrete slabs, provides a warm and dry floor
Or foamboard; BSI-003: Concrete Floor Problems — Building Science Information
Gary
Old 10-14-13, 08:25 PM
Thank you both for the replies. A user on another forum also suggested using EPS foam with plywood on top. He said that sleepers would just create a mold farm.
Old 10-15-13, 03:39 AM
I worked for a carpenter once & he put plastic under the sleepers. I don't know if that was correct or not. Also, it was a garage conversion not a cellar.
