Raising subfloor question.
Old 11-12-13, 07:20 PM
T
If you are assuming everything before the point of my question has been done properly... Long story short, if using OSB Sheathing:
7/16 in. x 4 ft. x 8 ft. OSB Sheathing-386081 at The Home Depot
there is a smooth side and a rough side. Which side faces up?
Old 11-12-13, 09:57 PM
G
The rough side is for walking on, usually ink-print layout on 24" centers for trusses. The smooth side is waxed from manufacturing to keep them from sticking while pressing. Very slippery on a roof....so I've heard. Don't forget the ply clips if required per local code.PSCL/PSCA Panel Sheathing Clips Only for roof/wall, not subfloor....unless perimeter blocked, per code.
Gary
Old 11-12-13, 11:50 PM
T
Thanks Gary. I needed to know that because I didn't think the glue side would be good for anything. It isn't being used as the subfloor, but being put on top of the concrete subfloor to help raise it. I've waterproofed the concrete (because it has some moisture problems) then laid cement boards. It still needs just over a half an inch to go, so that's where those boards come in. On top of that would go hardwood flooring.
I'm also putting joint glue for the OSB.
Old 11-13-13, 03:45 AM
Tile board should not have been used in direct contact with the slab.
There is no way to water proof a slab from the top side.
Old 11-13-13, 11:45 AM
Received 97 Votes on 85 Posts
If you're laying wood for the floor, why do you have a layer of cement board?
I'm apparently missing something, your plan doesn't make sense to me.
Old 11-14-13, 12:34 PM
G
Hardwood flooring requires a moisture retarder between it and a crawlspace. On a concrete slab, it requires a full-fledged moisture barrier= poly sheeting. IMO, add some rigid foam board on some 6mill. poly directly on the slab. Then add your shim stock/plywood fastened down. OSB (7/16") is not nearly as good compared to plywood; with 3/4" the best thickness for holding fasteners in your application. Though 1/2 ply may be acceptable.http://www.buildingscience.com/docum...bef2a9fb9809f2
How muck thickness from the slab are you needing to finished elevation?
Gary
