Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
How big of a hole can I drill through a double top plate for plumbing?
Old 01-21-14, 08:37 PM
T
I have a little bit of a plumbing problem. I am trying to run a vent for a washing machine up and through a double top plate (i.e., two 2x4 horizontal studs). I am pretty sure that the double top plate I am trying to drill through is load-bearing. The vent pipe is 2" which means that the hole is going to be really big.
I'm not sure what to do. Does anyone know what the maximum hole size I can drill in this double top plate?
Old 01-22-14, 04:26 AM
chandler's Avatar
Received 6 Votes on 6 Posts
You can drill the 2 1/8" hole through both top plates, as long as you install two no-nail plates or a 3" mending plate across where the hole is. This will keep you from driving screws into the pipe later on. This is assuming you have standard 16" oc studs.
