Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Removing closet and converting closed stair to open stairs--HELP!
Old 05-08-14, 09:18 PM
C
I have a closet underneath my staircase and the walls end about half way up the staircase itself. I know the stairs are supported by the stringers but I'm curious about the closet walls. They seem to be 2x4 in width. I haven't opened them up yet to check anything.
We want to remove the closet and convert the stairs to a riserless, open staircase. It would open up a huge area between the living room and kitchen.
I guess the question is are these load bearing walls or not? How can we tell?
Old 05-09-14, 03:21 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums. We recommend prior to engaging in such an aggressive remodel, where much material is removed, a structural engineer to be brought in and give blessings or recommendations as to its viability.
Old 05-09-14, 05:53 AM
P
Do not get a structural engineer. I mean seriously? You haven't even removed any drywall around the closet or the stairs to see how they are framed. That would be the first step if you are serious so you can see if it is actually possible. Why pay some guy hundreds of dollars so he can Google the same thing you could Google? Or get information from the city for free that you could get? Go get your house plans from the city, remove some drywall on the inside of the closet so you can see how it is framed. Get pictures.
Old 05-13-14, 12:11 AM
C
Do I want to remove the drywall so I can see the floor joists above the closet? I've done lots of research and it seems that's the biggest indication of a load bearing wall. Floor joists running perpendicular to the wall.
Thanks for the advice.
Old 05-16-14, 05:26 PM
C
So I removed some sheetrock and the two walls on both sides of the stairs and they are load bearing walls. They each have a room above them.
If I were to replace them with beams they would be 29' and 23' beams. I'm guessing they will have to be steel. Any ideas how much something like this would cost?
