Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
2nd Floor raised above the first floor wall...how serious is this?
Old 06-01-14, 09:12 AM
N
These forums are very very useful and thanks to al guys helping each other !
I just bought a house for my family which is two story in San Jose CA area. After I got the key I called some floor guys to give me the estimate for refinishing the floor (its wood floor) and during their visit they pointed to some issue which neither I could catch earlier not my building inspector.
There is a wall on first floor, which is beneath a room upstairs and that wall passes through almost middle of each that room. Where that wall passes through that room, floor is raised a bit (almost 1,2 degree).
There is no foundation issue in the house and no cracks in the window corners, door corners so I am confused what it is? One of the guys who was at my house for floor estimate mentioned that probably that room are sagging down around a beam on top of 1st floor wall. I have my inspection come again and check that next week but I am worried if I ave bought something which need lot of money to get repair.
Thanks in advance for advises !
Old 06-04-14, 06:05 PM
P
Temporarily Suspended
"There is a wall on first floor, which is beneath a room upstairs and that wall passes through almost middle of each that room."
That doesn't make any sense. What does "almost middle of each that room" mean?
Old 06-05-14, 06:10 PM
BridgeMan45's Avatar
Received 1 Upvote on 1 Post
If you post a few pictures of what you have, it will be easier for us to understand your problem.
Old 06-05-14, 10:03 PM
N
I meant "almost middle of that room"
Old 06-05-14, 10:17 PM
Received 3,485 Upvotes on 3,128 Posts
A house and it's load bearing supports are extremely important. From what you are describing it sounds like maybe a load bearing wall was removed and now your second floor is sagging/ settling. Without pictures we can't begin to help you as it would only be a guess. Even with pictures it can be difficult.
http://www.doityourself.com/forum/el...-pictures.html
