Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Pics: Cat and dog pee on osb subfloor from last owners...
Old 06-15-14, 12:22 PM
A
Here are the pics, do you think we can clean it and seal with BIN?
The smell is so strong, the people selling put down new carpet and new padding but this is underneath. We are told 10 tiny dogs and about 10 cats and they were believed to have been kept in this room while they were at work. No other room in the house has anything on subfloor just this room.
What do you think? The process we are going to try is blot up excess sticky residue, clean with white vinegar and toothbrush, wipe up let dry and put baking soda down and rub in with toothbrush, let sit for a couple of hours, vacuum, then seal with zinssers BIN. Thoughts?
Old 06-15-14, 01:11 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Remove and replace the subfloor.
There is no reliable and satisfactory way to eliminate the odor you have described.
No matter what you do, it will return, so just rip it out and replace. Problem solved.
My $0.02
RR
Old 06-15-14, 05:03 PM
P
Temporarily Suspended
I never would have bought the house. Rough Rooster is right. There is no way to remove cat urine smell.
Old 06-15-14, 06:49 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Small room...cheaper and easier to rip out and replace.
Old 06-15-14, 07:22 PM
A
This house is perfect for us, our budget and location. The one room wasn't a deal breaker.
It is a small room and would be reasonable to replace but I don't know if I'm ready (or skilled enough) to tackle this.
The husband went this morning and cleaned it off with process he planned on and let it dry. After dinner he went to the house and put on 1 coat of BIN. I'll update Wednesday night as that's the next time I will get down there.
Old 06-16-14, 03:43 AM
Received 753 Upvotes on 658 Posts
1 coat of BIN should be sufficient provided it was a heavy fluid coat! The pigmented shellac needs to completely cover all the subfloor and flow into all the cracks/joints.
btw - welcome to the forums!
Old 06-16-14, 09:28 AM
Received 1,197 Upvotes on 1,152 Posts
I'd have replaced as well.
That said, the BIN might take care of this for you.
Now, did the animals pee up the walls at all?
Old 06-16-14, 06:35 PM
A
I'm going to assume so with the up the walls as the bottoms of the wall in that room had mold so we cut about 12 above whee it ended and cleaned the joists with bleach. This house is a mess I really wish we weren't in this situation right now. The floor registers I took out to clean and found pee in there, dog food cat food just nasty. I vacuumed them where I could, cleaned the register portion with bleach and ripped off all the nasty foil tape and applied new to seal the connections. I put borax down there to absorb odor and moisture and I won't even post a pic of what the borax in there looks like now
Old 06-16-14, 06:39 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
After you put bin down I would close up room a couple of days and than go in to see if odor is gone. Do this before you put anything else down on floor. If odor still there a new sub floor is only answer.
Old 06-16-14, 06:40 PM
A
Basically the more we fix the more we find and what's the breaking point, we don't know. We still haven't moved in as we have 3 little boys and we signed the rent to own agreement may 7th. Had the mold inspector come and of course results show abnormally high levels after we cut holes in the walls
