OSB+T&G+wall construction
txtown's Avatar
TX
06-24-14, 05:56 AM   #1
I'm building a 12x32 workshop. Ground is covered with 6 mil plastic. Subfloor is 19/32" OSB, covered with roof felt for moisture barrier, then 23/32" T&G plywood. The T&G plywood will eventually get painted or covered in vinyl flooring. I've made it through all the foundation (piers and beams) work - and am just about ready for the perimeter and floor joists.
My question is: Should the walls be built on top of the OSB - with the T&G cut back to occupy just the "inside"? Some forums have suggested the T&G needs to float due to expansion/contraction.
Or do I just lay both the OSB and the T&G and build the walls on top of both?
marksr's Avatar
TN
06-24-14, 06:21 AM   #2
Something doesn't make sense you've installed the subfloor but not the floor joists
I'd erect the walls before installing a 2nd layer of plywood. IMO one layer of 3/4" plywood is plenty good enough for a shop floor.
retired painter/contractor avid DIYer
txtown's Avatar
TX
06-24-14, 06:31 AM   #3
just making sure my ducks are in a row before I do any flooring over the joists.....
I'll finish up the perimeter (double all the way around) and floor joists, and solid blocking today/tomorrow.....then the flooring. Hence wondering if the walls should sit atop just the OSB or the OSB+ the plywood.
But it would be nice to figure out how to build the roof on the ground - and THEN set it on top with just two guys! LOL! Ten foot down seems much more perilous than it did 30 years ago....
