Screw pattern and size for 3/4" plywood subfloor?
Hey there, I'm getting read to screw and glue some subfloor in. I bought subfloor glue and will be putting it on the joists (should I just do a zigzag?) before I screw them in. To screw them in, I was planning on getting #8 2" fully threaded construction screws.
Is that a good idea? Should I get partially threaded instead? Should I alternate between full and partially threaded? How many inches between the screws?
Thanks a ton guys!
Thanks a ton guys!
Not sure what a "construction" screw is, but I recommend using Torx head decking screws. Partially threaded will tend to pull the wood down to the joists better. 8-10" in the field is sufficient. Now, if you are going over this subflooring with another layer, no glue and intentionally miss the joists with the next set of screws.
Are you using Advantech or similar subflooring or just plywood? No big deal, just Advantech is a subfloor which is tongue and groove and is wax impregnated to prevent water damage during construction.
MULTI-MATERIAL CONSTRUCTION SCREWS
and
Grip-Rite 2 in. Construction Screw (1 lb.-Box)-2GCS1 at The Home Depot
The second one looks much like a deck screw except uncoated.
The SPAX is probably much stronger, but I imagine more expensive.
I'd use the partial thread, you want to pull the layers together and a full thread can sometimes cause the upper piece to walk up slightly.
and
Thanks guys! Chandler, I looked everywhere I could for adventech. EVERYWHERE! My gosh that stuff is hard to find. All osb is generic in my area.
Weird question: let's say I can't find #8 2" coated screws. Could I use #9 2"? For some reason that size (coated) is not common.
Hahaha, hey, I'm stupid when it comes to this stuff but not that stupid; I eventually pick up on the stuff you guys tell me!
I knew it was just a slight size difference but asked because knowing my luck I'd end up ruining something due to some unknown rule lol.
Well, thanks again mr chandler!
