No DIY Experience, and I Fell through my floor today! Help!
CloverMama's Avatar
ME
09-05-14, 05:51 PM   #1
So, I know next to nothing about home repair, my husband and I just moved into a "new" trailer, and today I fell through the floor while walking through the front door. Its clearly rotted out, and I was hoping someone could let me know the basic idea of what I need to do to fix this. Thank you!
CloverMama's Avatar
ME
09-05-14, 06:15 PM   #2
Peas and Love : Photo Here is a picture.
ray2047's Avatar
TX
09-05-14, 06:57 PM   #3
My bet is it is particleboard and it has gotten wet. This is probably not a beginner DIY project because first you may have to rip out a good bit of floor just so you can get to where you have good floor., plus you often have to improvise repair methods as you go along so you need previous experience to base the improvisation on. Can you step back and give us a wider area shot. http://www.doityourself.com/forum/li...-pictures.html
But if your up for it it can be a good learning experience and we will be glad to answer your questions.
I can explain it to you, but I can't understand it for you.
marksr's Avatar
TN
09-06-14, 05:11 AM   #4
Most MH floors are 5/8"particle board. You'll need to remove the tile, cut out and remove the damaged portion and then install 5/8" plywood or OSB. You might need to add some framing to attach the new plywood. The floor joists are likely 2x6s. Depending on the overall condition of the trailer floor, I often patch all the bad spots and then overlay the floor with 3/8"-1/2" plywood to make a nice smooth subfloor.
MHs are notorious for damaged PB along the perimeter and near plumbing, basically anywhere it gets wet.
retired painter/contractor avid DIYer
CloverMama's Avatar
ME
09-06-14, 04:47 PM   #5
Thank you! I will try to get a better picture and upload it here. I'm always up for a challenge and learning new things, so if this is potentially something I could do on my own, I would love to. Thank you for replying.
