need help in determining if wall is load bearing
harleyRG's Avatar
CO
09-18-14, 04:41 PM   #1
I have a second story wall that backs to attic space and would like to know if it is load bearing or not. i want to remove a portion of 1 of the 2x6's to frame in an access panel to gain access to the attic. i am nervous if temporarily removing a portion of 1 stud to frame in an access panel will cuase issue and whether a will need to frame in a header on top of my access panel.
Attached are a few pics. The second story wall does not have a wall below it on the first floor if that makes a difference, and the roof trusses that are just in front of the 2x6 wall are attached to the header joist that that the wall sits on
NJ
09-18-14, 05:41 PM   #2
Temporarily removing a stud will not cause a problem but I would definitely install a double header over you opening to pick up the cut stud.
BridgeMan45's Avatar
OR
09-23-14, 11:06 AM   #3
Hopefully, you do mean studs, and won't be removing portions of fabricated trusses, right?
Handyone's Avatar
CAL
09-23-14, 05:12 PM   #4
I think maybe he does bridgeman.
Harley, see picture:
Attachment 38795
If it's the one with arrow (or any of the adjacent vertical members), no.
Brian
Cal Contractor
NJ
09-23-14, 05:46 PM   #5
Sounds like he's referring to the 2x6 wall and not the trusses.
Handyone's Avatar
CAL
09-23-14, 05:51 PM   #6
My bad,
I see now. Trusses are not 2 x 6 anyway.
Brian
Cal Contractor
