IL
08-26-15, 06:42 AM
Doorless doorway
Hello, I am looking to open up a doorway between my foyer and living room. I use 'doorway' loosely as there is no door there. It is a rather wide opening as is (close to 5' or so), and just looks to be a transition between the two rooms. The wall is parallel with the floor joists so I am not too concerned about it being load bearing. My question is with regards to the header. I don't see any reason why it cannot be removed, but wanted to check to see what experience is out there regarding a header between 2 rooms...where there is not (or never was) a door. My guess is that it was for appearance purposes to show a separation between rooms. I just want the ceiling running from one room to the next with no interruption.
Thanks for your help
TN
08-26-15, 08:05 AM
You need to determine if it's a load bearing wall. If it's load bearing the header must stay [maybe replaced with a bigger one depending on how you open it up] Do you know if the floor/ceiling joists run parallel to or across that wall?
retired painter/contractor
