Stair Stringer Cuts For Treads Not Exact
Old 09-22-15, 06:19 AM
A
Received 109 Votes on 101 Posts
I was cutting a stair stringer with a saber saw and the cut did not come out exactly square. The treads are the proper distance apart vertical and each tread rests on the stringer at the proper level without rocking but a tread actually touches the stringer in only a few spots with a (horizontal) gap ranging up to 3/32 inch underneath.
Is it okay to use the stringer this way anyway where the tread and stringer wood will compress a tad over time although still not eliminate the gap completely?
Similar question: The ends of studs for framing a wall did not come out exactly square. The stud fits snugly but there is still a thin gap at the top cap and sole plate. Can these studs be used as-is anyway?
Old 09-22-15, 06:39 AM
W
Received 22 Votes on 21 Posts
Stringer
I think you will be OK as long as the treads rest solid without rocking.
I always cut stringers with a circular saw and finish out the corners with a hand saw or jig saw.
Old 09-22-15, 06:42 AM
Received 361 Votes on 318 Posts
Would adding an adhesive to the top of the stringer cut make up for the areas where it is low?
Old 09-22-15, 09:55 AM
W
Adhesive
Good thought, Mark. I agree.
Old 09-22-15, 11:08 AM
XSleeper's Avatar
Received 790 Votes on 727 Posts
Use construction adhesive, it will take up the voids.
Old 09-23-15, 10:55 AM
A
The construction adhesive looks like a good gap filler to use. Thanks.
