Screw types for metal stud framing?
Old 10-10-15, 08:21 PM
Question Screw types for metal stud framing?
HI! I see two different type of screws for framing and I have checking all kinds of videos and its never clear which one is for which.. On some videos it shows a wafer head and others it appears to be pan head .. ( though the pan head does protrude more than the wafer head )
Panhead versus Waffer head..
I am building metal stud walls and I want to know what is normally used to attach the stud to the frame base..
Old 10-10-15, 09:16 PM
Welcome to the forums.
I prefer the wafer head style as the head doesn't push the sheetrock too far off the stud.
The ones on the left are self-drilling with a little drill point built in.
The ones on the right are super sharp and just penetrate the metal studs.
I see both used on jobsites. They both have their advantages. The self drilling are a little easier to use.
Old 10-11-15, 04:26 AM
thanks for the response.. I was not sure if I could use panheads for the drywall side..although I do agree with you about the gap it can leave.
The image of those wafer heads shown in the pics is what I was also leaning towards using as well..
Thanks for confirming it
