Does this subfloor have to be replaced?
Old 05-19-16, 12:33 PM
R
Good Morning, This is my first post on this site, so here goes.
I am attempting to mitigate some water damage and rot from a poorly sealed door frame. The door faces the west shore of a large lake in the pacific northwest and receives a moderate to heavy amount of precipitation against it. I know I need to replace the doorjamb and drywall but I was hoping I could still use the subfloor. The floor isn't spongy at all but it it is discolored and a little rough in places. It doesn't appear that it would be that easy to repair since it has a railing involved, either that or I'm missing some easier solution. Please help so my wife will stop asking me when I'm going to finish it.
Old 05-19-16, 01:03 PM
Received 361 Votes on 318 Posts
Welcome to the forums!
Discoloration doesn't hurt any but does the plywood still lay flat all the way across? You do intend to pull the threshold and properly seal it, right?
Old 05-19-16, 02:08 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
Looks like the door jamb took the brunt of it. If anything, make the determination on the subfloor when you are replacing the door. At that time, you will be able to see everything all the way to the edge of the plywood. Make sure you install a door pan this next time to avoid similar issues. You also need to order your new door with a rot proof jamb.
Old 05-19-16, 04:40 PM
Received 83 Votes on 78 Posts
Looks like once again someone missed the class on building 101 and there a slab pored even with the threshold, which is a sure way to have water coming in under it and taking out the subflooring, bottom plates, sheathing, Ect.
Post another picture of the outside further back please.
Old 05-21-16, 10:49 AM
R
Thank you so much for your reply? Do you have a recommendation on a good jamb and door pan? I would like to order from one of the box stores since they are so close, however if i need to go to a builder supply i can do that too. Thanks.
Old 05-21-16, 10:53 AM
chandler's Avatar
Received 6 Votes on 6 Posts
You'll have to order it, but it is available. You may need a wider one, depending on the thickness of your walls. SureSill 4-9/16 in. x 78 in. White PVC Sloped Sill Pan for Door and Window Installation and Flashing (Complete Pack)-HDO 4_63S 080 - The Home Depot
Old 05-21-16, 01:33 PM
My local Home Depot has then as well as my local lumber yard.
