is this a load bearing wall???
Old 07-18-16, 11:25 PM
I think it is a load carrying wall , but I wanted to confirm...
It has 10 or 12" beam sitting on top and its going perpendicular and then two smaller boards attached to the beam running on top of headers of the wall
there is no attic to check
Thanks for any advice!
Old 07-18-16, 11:40 PM
Received 1,347 Votes on 1,245 Posts
Welcome to the forums.
http://www.doityourself.com/forum/el...-pictures.html
Old 07-18-16, 11:47 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The only image I could salvage was:
None of the files you tried to post as image files were image files. Please just post links instead. Let the board make them clickable.
Old 07-18-16, 11:57 PM
The pictures are in drop box. I snagged the others.
Old 07-18-16, 11:59 PM
Ahhhh..... now there are pictures everywhere.
Old 07-19-16, 12:16 AM
Thank you!
so any ideas about that wall, I know there is not much you can see...
Old 07-19-16, 10:46 AM
ray2047's Avatar
What's above the wall? .
Old 07-19-16, 11:11 AM
Handyone's Avatar
You are correct, there's not much to see.
I suspect the wall is bearing for only one reason:
At the left end of the short wall there is a 4x4 post. Posts are not normally installed unless they are supporting a beam above it.
If the wall served no structural purpose, I would not expect to see a post and "anything" would have sufficed other than the post. You would expect to see a single 2x4 at the end for a non-bearing wall.
So it's hard to say. I know I wouldn't remove it without knowing.
