Backerboard thickness for tile floor?
i currently have a 1/2 inch ply floor in bathroom + a 1/4 inch ply over the 1/2 where by old vinyl flooring was. if i rip up the 1/4ply and lay down 1/4 backerboard will that be sufficient for applying tile? thanks
Probably not. What's the size, spacing and unsupported span of the floor joists?
Ceramic/porcelain or natural stone tile?
Every tile is different, you have to refer to the manufactures guidelines.
A "general" guideline is 1 1/4" thickness of solid flooring.
1/2" is too thin.
Also what's the size, spacing and free spans of the joist?
Tiles a one shot deal if you want it to not crack.
total bathroom size is 80x 60
tile area is 60x60
i plan on using a 12x12 ceramic tile.
i don't actually have the floor pulled up, but based on the nail lines it looks like 16" gaps
What would be your recommendations on how to proceed with flooring? do i add another 1/2 ply and 1/4 backerboard although I currently only have just short of 1/2 from floor to top of door threshold.
Could i get away with taking out the top 1/4 layer and adding 1/2 backerboard? I'd prefer not to have a big rise into bathroom from hallway. thanks
tile area is 60x60
Bear in mind backer does not add strength needed to the flooring. If that is 1/2", then another 3/4" is recommended plus 1/4" backer. You may have to threshold the doorway, but it will be a more solid floor in the long run. And, yes, remove the 1/4" first.
Biggest mistake in installing tile is get hung up on the difference in height created by the proper substrate.
You can cut material off the bottom of the door to clear the new tile floor, done all the time.
1/2" ply + 3/4" ply + thinset + 1/4" backer board + Tile would be the optimal sandwich.
