Reinforce Load-Bearing Wall
I recently started my first project to update our new house. This was originally built in '49, but has been added on to several times. I noticed this after I finally removed the tongue and groove/inverted lap siding mix from the walls of the bedroom.
My questions are about the load-bearing wall pictured below. The "on center" measurements are listed on the picture.
https://drive.google.com/open?id=0B3...ZkRFpjQktaLWtz
FYI, this is a pier and beam ranch-style house. All beams/piers/floor joists were replaced last summer. This wall is running parallel to the middle beam.
First, should I add studs to support between the 24s?
Second, could I bulk up the support on the right, i.e. remove horizontal supports and add vertical, to put in a closet door? The electric would be rerouted. I think it may have been a window at some point. A neighbor told me that the bedroom on the other side was once a deck.
I'm not too comfortable just slapping up drywall and calling it a day.
Thanks for any thoughts or advice!
