Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Anyone Have an Educated Guess on a Corner Stud Layout
Old 01-03-18, 04:30 PM
H
Received 5 Votes on 4 Posts
My house was built in 1902. The walls are lath and plaster with a drywall overlay, so no chance of locating studs normally. I am hanging a TV on an inside corner (outside exterior corner). When I drill perpendicular into either inside wall (within 3/4" of the corner), the wall is hollow. If I drill @ 45 degrees directly into the corner, there is solid wood. I can't wrap my brain around what the corner detail framing might be.
I am in Boulder, CO and suspect that all building materials were relatively expensive around 1900, so they probably didn't use any extra lumber. This was a miner's house so perhaps not built to the standards of the elite just a couple blocks away.
Old 01-03-18, 04:35 PM
P
Received 747 Votes on 686 Posts
I assume the corner studs are somewhat traditional but with a layer of lath and plaster capped with sheetrock the finishing may be so thick that the face of the wall is out beyond the framing.
Old 01-03-18, 04:48 PM
H
I think you are on the mark Pilot. I thought of this after I posted. There is 1/2" drywall and probably 3/4" of lath and plaster, so when I drill a pilot hole 3/4" from the drywall corner, I am 2" from the framing corner. I'm gonna need some pretty long lags to attach blocks to the inside corner to then bolt my TV bracket into.
Thanks for the quick response.
Old 01-03-18, 04:49 PM
XSleeper's Avatar
Received 784 Votes on 722 Posts
There is not always a stud on inside corners on those old houses... the lathe often runs behind the corner to the next stud if the wall continues that direction. And they used any kind of crap when they needed backing for the lathe in a corner so don't count on a stud.
Old 01-03-18, 06:35 PM
Received 1,324 Votes on 1,224 Posts
If your TV is large enough to cover..... you may need to mount two pieces of plywood to the wall and then mount the bracket to the plywood.
Old 01-04-18, 08:36 AM
H
I have stacked two 2 x 4 short lengths in the corner and if my math is correct, I need an 8-9'" lag screw going in at 45 degrees, where I detect wood with a pilot hole. My TV weighs 50 lbs. Hope this does it.
