Rockwood in floor/ceiling support
Old 12-16-18, 07:56 PM
Q
Received 1 Vote on 1 Post
I want to put in roxul in the floor of a 3rd floor apartment, which is the ceiling of the 2nd floor below. Where is the correct positioning of the wool in the cavity or does it not matter? ie touching the ceiling below or leaving a gap? How can I support the roxul so that it doesn't fall down and touch the drywall below but is instead snug against the flooring of the 3rd?
Lastly, is a double layer of wool better for soundproofing?
Old 12-16-18, 09:29 PM
Marq1's Avatar
Received 374 Votes on 349 Posts
It doesn't matter, you are just filling the cavity for soundproofing so just fill with a min of 6" (R19) or more!
Old 12-17-18, 03:50 AM
Q
I figured that if anyone worked on the ceiling below in future, all the insulation would fall down.
Old 12-17-18, 03:21 PM
Q
Also, how do I put 24" roxul into a space of 27"?
can I cut it and put strapping to support it?
Old 12-17-18, 04:29 PM
Marq1's Avatar
Is the ceiling open?
You have 27" joist spacing?
Old 12-17-18, 04:42 PM
Q
Yes, entire house is like that. 27" spacing, 3"x11" actual width not nominal
