Drilled holes closer than 2" in sleepers
Old 09-20-19, 11:34 AM
G
Hello all,
I am converting my garage into a living space and I raised the floor using 2x4 sleepers to make it the same level as the rest of the house. I ran some of the wiring through the sleepers and I just realized that the holes I drilled for the wiring is closer than 2" to the bottom of the sleepers. I have already run and secured the wires. Is there a way to secure this? I have an inspection coming up and I don't want this to be a problem.
By the way there are only 3 locations where I made these holes and they are at the end or pretty close to the end of the sleepers (lengthwise).
Thanks!
Old 09-20-19, 11:42 AM
XSleeper's Avatar
Received 720 Votes on 666 Posts
I don't think they will care. Sleepers aren't like joists because there is no span to consider, since sleepers are usually fully resting on something solid.
Old 09-20-19, 12:13 PM
G
They are resting on adjustable plastic supports every 42" or so. Would that make a difference in span consideration? Thank you!
Old 09-20-19, 01:19 PM
XSleeper's Avatar
Maybe. Depends how anal the inspector wants to be. Doubt they will say anything.
Old 09-20-19, 01:21 PM
Received 330 Votes on 293 Posts
What if you ripped a piece of 2x to snugly fit between the floor and the sleeper [instead of the plastic support]
Old 09-20-19, 01:53 PM
Received 1,187 Votes on 1,098 Posts
That should be ok. No way to get hit by a nail.
Old 09-20-19, 06:28 PM
G
Thank you all. I guess I will wait until the inspector sees it.
Old 09-21-19, 03:15 AM
Most inspectors are pretty good with providing you the info on what needs to be done IF you fail inspection.
Hopefully it all goes well!
