Floor Trusses Installed Crooked
Old 11-17-20, 10:27 AM
Y
The house I am building has some floor trusses at an angle. I hired replacement framers who already fixed dozens of other issues.
The 23/32" subfloor is glued with advantech subfloor adhesive and nailed to the trusses.
Is this necessary to fix and what would be the best way to do it?
Old 11-17-20, 11:41 AM
XSleeper's Avatar
Received 714 Votes on 661 Posts
If they are not plumb, it "might" create a small hump in the floor. You could cut them loose at the top plate and plumb them up and then renail them.
Old 11-17-20, 02:03 PM
Y
If there is no hump would you leave it be?
Old 11-17-20, 02:27 PM
XSleeper's Avatar
It ain't going anywhere....
joecaption voted this post useful.
Old 11-17-20, 03:02 PM
P
Received 681 Votes on 628 Posts
You're not going to get the top of the truss free so that leaves you with the bottom. You can use a reciprocating saw to cut the nails then kick the bottom of the truss over the 1/2" or whatever it needs.
